Discount Parts For Kenmore Water Softener? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2008, 11:41 PM   #1
Discount parts for Kenmore water softener?
I have a Kenmore water softener (model 625.3485500) with a broken Brine Valve Assembly. The part from Sears is $75. I refuse to pay that much for plastic. I have found a few sites online, but so far have not found the part I need.
Here is the part:
http://www.searspartsdirect.com/part...3689&pop=flush
unknownsoldierx is offline   Reply With Quote
Old 05-22-2009, 11:50 AM   #2
Wide range DIY'er
Parting out my Kenmore Softener
Hi,
I saw you were looking for a part last year...don't know if you had any other parts needs for this model softener. I have one that I no longer need, as I just went to a city water supply.
I'll be pitching out the 'larger' parts that don't tend to break, but this softener has been working troublefree for about 10 years.
Parts that may need replacement include the timer, the venturi assembly, and other 'small' parts like clips and what not that may be difficult to replace.
If you have a need for some parts , let me know.
MintHillian is offline   Reply With Quote
Old 08-09-2009, 09:50 AM   #3
Softener timer assembly
Hey There Hintmillen
I am in need of your timer brain assembly for the 625.3485500 kenmore softener, mine won't power up the valve motor anymore. Tested the motor works fine, but my circuit board got wet and stopped working. My e-mail is mottcorey@hotmail.com. Could really use your timer board !
Corey
cameronboii is offline   Reply With Quote
Old 08-09-2009, 09:51 AM   #4
Corey
Old 03-05-2012, 06:52 PM   #5
water softener parts
I need a timer for a Kenmore 625 388 180. Part number is 7268617. Sears wants a mere $151.49 plus plus. Anyone know of discount parts?
tetheobald is offline   Reply With Quote
Old 03-05-2012, 07:58 PM   #6
Water Treatment
Rewards Points: 850
Try this site
http://www.softenerparts.com/North_S...rlpool_s/1.htm
Out side of that , maybe a used one showing up on the auction site.
Akpsdvan is offline   Reply With Quote
Old 03-05-2012, 08:16 PM   #7
Thanks, Akpsdvan. Which auction were you referring to.
Thanks Again
T
Old 03-05-2012, 08:25 PM   #8
Water Treatment
Rewards Points: 850
Starts with an E... and its by the Bay....
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Water softener entry point? tigerbalm2424 Plumbing 4 09-06-2007 04:50 PM
Hard water - 37 gpg, .088 iron content. What softener will work? fillys6 Plumbing 9 04-27-2007 10:55 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
