Disconnecting A Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2009, 01:24 PM   #1
Disconnecting a water heater
I have a water heater in my garage connected by copper pipes, i need to remove it temporarily to redo the floors. how do i disconnect the pipes. Use a blowtorch to heat the pipes or just cut the pipe with a tube cutter?
thanks in advance
homeguy is offline   Reply With Quote
Old 06-15-2009, 04:33 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
thanks in advance
I would cut the pipes with a tube cutter. Repair with sweat couplings when you put it back. Use compression couplings if you are not up to soldering.
rjniles is offline   Reply With Quote
Old 06-15-2009, 05:12 PM   #3
DIY'r
ScottR's Avatar
rjniles is 100% right as to the correct way to do it.
Personally, I'd heat a couple of the joints and pull them apart. Then before reinstalling, clean off all the old solder before putting it back together. This way there are less joints in the end, and no need to buy anything.
The reason rjniles' method is probably the preferred one is that if you don't clean the old joints extremely well then they may leak. Also, it's easier to damage things or deform the pipes my way. Lazier, too.
ScottR is offline   Reply With Quote
Old 06-15-2009, 05:14 PM   #4
Cut the tubing, when reinstalling install unions so it's easier when you have to replace the WH.
hayewe farm is offline   Reply With Quote
Old 06-16-2009, 03:41 PM   #5
Rewards Points: 1,548
I would say that getting the length of the pipes* right is much more critical when replacing a water heater using unions.
Unless there is vertical give in the pipes up above for example the pipes turn horizontally and run some distance before disappearing into wall or ceiling and can be bowed up or down a tad.
* The vertical sections just above the heater.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
