Disconnecting, reconnecting and purging gas lines.
Usually just a slit is made in the siding to get it over the piping & electrical conduit. Suggest contacting your utility regarding the disconnect from the main, if you do not want to cut the slit in the siding panel.
As for your question of purging, there is no need, just need to make sure that it does not leak when connected back up. From there you just have to relight the pilots on those appliances that use a standing pilot light.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
