Old 12-23-2011, 08:02 AM   #1
disconnecting an outside air conditioner
do I have to shut thr water off to disconnect the outside air conditioner
beyette is offline   Reply With Quote
Old 12-23-2011, 08:05 AM   #2
how to disconnect an outside air conditioner
Old 12-23-2011, 08:25 AM   #3
raylo32's Avatar
Say what? The lines to your outside air conditioning unit contain refrigerant not water. It is under very high pressure and needs to be recovered or pumped down before opening the lines. You need to call a pro to handle this.
raylo32 is offline   Reply With Quote
Old 12-23-2011, 08:11 PM   #4
STOP.......call a licensed professional to perform this service....do not attempt this very dangerous.....Ben
Old 12-23-2011, 08:16 PM   #5
Why are you disconnecting it? It's going to cost to get it back working again if that's the plan.
Old 12-24-2011, 08:31 AM   #6
"not diy call pro now"
COLDIRON is online now   Reply With Quote
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 12:12 PM
Disconnecting Central Air Conditioner MichaelJohn HVAC 14 11-23-2010 09:41 PM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 11:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 12:50 PM
