Discoloration Of Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2014, 09:37 AM   #1
Rewards Points: 30
Discoloration of Hot Water
I am on well water with several treatment systems, including iron oxidation, softening and "big blue" filter. I am getting a goldish brown tinge to my hot water only plainly noticeable in larger volumes such as a large basin or especially in the bathtub. The cold water is crystal clear. Should I drain the gas water heater?
ogbill is offline   Reply With Quote
Old 05-01-2014, 09:48 AM   #2
Rewards Points: 14,312
Yes, there is no need to completely drain it.
Just connect the garden hose to the drain run it outside and let it run for about 10 min.
If it's an older heater and it's never been flushed before it may not drain because of the solids on the bottom of the tank.
There's no need to shut anything off to flush it.
Once done remove the aerators on the faucets before running the water. It's going to stir up some trash and will need to be flushed out of the lines.
ogbill (05-01-2014)
Old 05-01-2014, 01:38 PM   #3
Water Treatment
Rewards Points: 902
You are also going need to check how often the different units are cleaning and for how long they are cleaning and at what time of day the different units are cleaning so that they are cleaning when no water is getting used normally that is 2am.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
ogbill (05-01-2014)
Old 05-11-2014, 04:38 AM   #4
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
anode rod failure
wctekkk is offline   Reply With Quote
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
