Disappearing Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2008, 10:40 AM   #1
Angry
Disappearing hot water
Got an older home,pier&beam where previous owner replaced all steel plumbing with PVC. It's a zoo underneath but I will redo soon. It takes forever to get hot water to the faucets THEN after getting it, you turn it off for a minute or so and it takes forever to come back. Like the hot water is not staying at the faucet. Whats up, where is it going.
ernie_workman is offline   Reply With Quote
Old 01-31-2008, 12:19 PM   #2
Rewards Points: 264
What do you mean by "its a zoo underneath"? Are you on a crawlspace? Are you in a cold region? Maybe the pipes are in an uninsulated wall?
Something is making them cool down rapidly between the water heater and the faucet when you turn the faucet off. Unless you turn on the faucet and air comes out, the water isn't going anywhere, its just cooling down in the pipes.
moneymgmt is offline   Reply With Quote
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
