Dirty Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2011, 01:58 PM   #1
Question
dirty hot water
we have a Munchkin boiler and a Super Stor hot water tank. We have recently been receiving brownish colored hot water. The time we noticed this was coincidental with our daughter son in law and two small children moving in with us for a few weeks. Any suggestions for dealing with the dirty water will be greatly appreciated
tom norris is offline   Reply With Quote
Old 06-27-2011, 10:01 PM   #2
When was the last time you fully drained and cleaned your tank? Sounds like the extra demand is stirring up some sediment from the bottom.
VIPlumber is offline   Reply With Quote
Old 06-28-2011, 06:42 AM   #3
Rewards Points: 1,538
Don't use any hot water for several hours. Then turn off the main water, open a hot faucet, and drain a few gallons from the hot water tank lower valve. This should not require more than 5 gallons.
If the city did a water main flush on your street and you used hot water during that time or shortly thereafter, you could get a quantity of sediment trapped in the hot water tank. This may take awhile to get rid of although draining the tank a little as described above, on 2 consecutive days, should clear it up faster.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
