Difficulty Removing Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2009, 03:29 PM   #1
Difficulty removing tub spout
I am attempting to remove an old Standadyne spout. This spout is hollow through the majority of its length and appears to be connected at the end. I cannot see or feel a set screw so I assumed it is a screw on spout. I was able to break the spout loose, but it does not screw off after many rotations. In fact, as it turns it vibrates as if there is a set screw.
RobMart is offline   Reply With Quote
Old 05-17-2009, 11:47 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If it doesn't unscrew after "many rotations", then it must have a set screw. Can't you see one in the slot?
Mike Swearingen is offline   Reply With Quote
Old 05-20-2009, 08:32 AM   #3
Solution
Spout was very cheap. The plastic shell had broken away from the copper screw on coupler, so the shell was just turning in my hands. I ended up cutting the plastic off to expose the coupler. From there, I could loosen the coupler with help of liquid wrench. Not very elegant, but the job is done. Now to replace it with a better spout.
Thanks for you response.
Tags
removing , tub spout
Bath tub spout leak issue abc Plumbing 1 01-26-2009 01:04 AM
Removing tub spout dummy14 Plumbing 20 11-17-2008 11:48 AM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
Difficulty removing grout ????????? nsb318 Flooring 12 02-19-2007 10:47 PM
