Old 07-22-2012, 06:08 PM   #1
Difficulty removing a slip-fit tub spout?
I am trying to replace a tub spout because the diverter does not hold a tight seal. I discovered the existing tub spout is a slip fit only after trying to unscrew the spout. Now the hole underneath the spout is not lined up with the bolt. It is a tight fit between the wall and the ring that is pinching the spout to the pipe. Any suggestions for how to get at the bolt?
campbeac is offline   Reply With Quote
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 04:12 PM
tub spout: slip on vs threaded (which is preferred?) Steve_P Plumbing 2 06-18-2011 10:00 PM
Removing Delta Roman Tub Spout stanart Plumbing 1 10-31-2010 06:20 PM
Difficulty removing tub spout RobMart Plumbing 2 05-20-2009 09:32 AM
Removing tub spout dummy14 Plumbing 20 11-17-2008 12:48 PM
