Old 01-14-2007, 04:58 PM   #1
Default Difficult Airlock Problem?
The hot water in my kitchen recently stopped working and I'm looking for solutions. It has happened once before, and I tried the traditional airlock solution of hooking up the cold water main line to the hot water feed in the kitched, which worked. This time though no dice. it has been very cold here recently, so maybe there is a frozen pipe issue, but none of the other pipes in the same vicinity are frozen, and this pipe is also insulated.
Also, and interestingly, I tried to drain the hot water tank to reduce the back pressure, but the tank wouldn't drain (turned off the cold water feed, turned off the gas/pilot, opened another hot water faucet, and opened the drain valve - nothing but a trickle). Seems wierd.
Any other ideas? I've thought about using hooking up a pressure washer to the hot water feed to try and increase the pressure to blow out the airlock, but I'm concerned this could damages the pipes.
Anyone dealt with a similar problem? Should I just bite the bullet and call a plumber? Help!?!
beachbum is offline   Reply With Quote
Old 01-14-2007, 05:01 PM   #2
It' not really possible to air lock a pressurize water line. You simply open the faucet the water pressure pushes the air out until you get water.
I think your idea of a frozen line is possible.
Old 01-14-2007, 09:26 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
What type of pipe is in your house?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-14-2007, 10:10 PM   #4
Copper in part , cast iron in part.
Old 01-15-2007, 10:16 AM   #5
Journeyman Plumber
A time ago there was some water heater that the dip tube went bad, don't recall the time lime, you could have one of those heaters and parts of the dip tube is finding it's way to your faucet. Just a possibility.
How old is your water heater?
More On This Topic
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I am going to take you through step 3 in our procedure for flushing a cooling system. Once your coolant has started to come out almost clear, you are going to go ahead and turn off your... Read More »
Hi, I'm Mark Emiley on behalf of Expert Village. In this segment, we are going to chill our wort and get it ready to put our yeast into. To do this, we're first going to take our wort and put it into the sink. Next, we're going to take our drain plug and... Read More »
Hi, I'm Mark Emiley on behalf of Expert Village. In this segment, we are going to chill our wort and get it ready to put our yeast into. To do this, we're first going to take our wort and put it into our sink. Next, we're going to take our drain plug and... Read More »
furnace problem captjack HVAC 8 11-23-2007 01:15 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 03:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 10:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 09:24 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 03:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
