Old 03-11-2010, 12:41 PM   #1
different size wax rings?
i'm noticing the grout nearest my toilet is starting to discolor from the toilet base moving outward. Me thinks i have a very small leak where the toilet connects to the flange (or whatever the big circle thing is called). and its seeping under my tile.
I think draining the toilet and pulling it up to check is simple enough. I did notice in the Depot that there are different size wax rings? how do i know which one to use? FYI the toilet and plumbing is only 4 years old.
Any other suggestions i should look for after i remove the toilet?
thanks!!
windowguy is offline   Reply With Quote
Old 03-11-2010, 06:43 PM   #2
I have never noticed different sized bees wax rings. I will have to look next time I am at the HD. What I have noticed is that some are just beeswax and some are beeswax attached to some type of plastic flange to help them seal better.
Jim F is offline   Reply With Quote
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 11:33 PM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
