Old 04-25-2011, 09:15 PM   #1
Question
Different locations low hot water pressure
Low Pressure inside house
I have similar problem yet with a strange twist.Cold water in Kitchen,vanity,bathtub and outside hose bib are just fine.
Clothes washer works like a champ.
Kitchen sink single control handle goes great cold yet when moved to the right, hot water has trickle flow.Vanity has good pressure.Bathtub mediocre flow.
Question: Why only some and not all ?
I have checked drain spigot at base of water heater.I made sure that all supply valves were open ( lefty loosey ).
WTF ?
At wits end
Last edited by woodye85741; 04-25-2011 at 09:17 PM. Reason: tags,low pressure,hot water
woodye85741 is offline   Reply With Quote
Old 04-26-2011, 06:04 AM   #2
The problem is not in the main lines. It is in the branch lines,shut off's or possibly the fixture itself. What you describe is a combination of separate problems not just one problem.
plumberinlaw is offline   Reply With Quote
Old 04-26-2011, 12:38 PM   #3
Angry
I try to remove moen style control lever to flush out hot water supply line at faucet yet cannot remove lever as I cant see screw that attaches. Is it hex key or standard screw ? all hex i have and try dont seem to fit snugly. Yet another
poser to solve problem. I will try to remove supply line from valve and base of faucet and see what happens.
Tags
hot water, low pressure
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
