-   -   Different locations low hot water pressure (http://www.diychatroom.com/f7/different-locations-low-hot-water-pressure-102723/)
woodye85741 04-25-2011 08:15 PM
Low Pressure inside house
I have similar problem yet with a strange twist.Cold water in Kitchen,vanity,bathtub and outside hose bib are just fine.
Clothes washer works like a champ.
Kitchen sink single control handle goes great cold yet when moved to the right, hot water has trickle flow.Vanity has good pressure.Bathtub mediocre flow.
Question: Why only some and not all ?
I have checked drain spigot at base of water heater.I made sure that all supply valves were open ( lefty loosey ).
WTF ?
At wits end
plumberinlaw 04-26-2011 05:04 AM
The problem is not in the main lines. It is in the branch lines,shut off's or possibly the fixture itself. What you describe is a combination of separate problems not just one problem.
woodye85741 04-26-2011 11:38 AM
I try to remove moen style control lever to flush out hot water supply line at faucet yet cannot remove lever as I cant see screw that attaches. Is it hex key or standard screw ? all hex i have and try dont seem to fit snugly. Yet another
poser to solve problem. I will try to remove supply line from valve and base of faucet and see what happens.
