Dielectric Unions Vs. Brass Vs. None On Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2011, 07:35 PM   #1
Rewards Points: 93
Dielectric Unions vs. Brass vs. None on Water Heater
I have never taken apart a hot water heater, but am under the impression that they are now made with glass-lined steel tanks. Does this mean that water heaters should use di-electric unions? What about using a section of brass pipe in place of the di-electric union? Is this an acceptable substitute? My experience are that di-electric unions are marginally usefull at best.
Perry401 is offline   Reply With Quote
Old 05-07-2011, 09:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
Di-electric unions are only used on gas meters. Gas co. sends a low voltage down it's line to repel moisture/prevent corrosion and the union keeps it from going into the house. Water heaters can be hooked up with straight copper to brass mip or fip adaptors or any other materials (except plain black iron pipe).
Old 05-07-2011, 11:28 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 678
In my area (UPC) dielectric unions or nipples are required between copper and steel. Brass transition does not meet the code standards but is usually allowed by the AHJ. Water heaters here are required to have unions no matter what type of pipe you are using. This can be done by using flex connectors too.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
