Old 12-23-2013, 07:27 PM   #1
Share |
Dielectric unions leaking on water heater
For the past several days my 4-5 year old water heater has been leaking somewhat from the top of the dielectric unions. It is a A.O. Smith Power Shot so it is a very expensive job to replace. I installed it myself-apprenticed to a plumber during college. They seem a bit corroded but nothing I can't wipe away. Thoughts?
Wadman2 is offline   Reply With Quote
Old 12-23-2013, 07:38 PM   #2
DIY staff
Have you tried tightening them? The gaskets(washers) might be shot,but can be replaced easily with a few turns of a wrench---
Wadman2 (12-23-2013)
Old 12-23-2013, 07:44 PM   #3
Builder never installed shutoffs so I was waiting till tomorrow when I can shut household water off. I'll install shutoffs too. I didn't know I could replace those seals.
Is the Dielectric union a right hand thread? I bought them from DIY so I'll stop there and ask for replacement seals before I try to disconnect them. Do they usually disconnect without major problems?
Old 12-23-2013, 08:17 PM   #4
Thanks. I just went and tightened them. One went 3/4 of a turn. It must have loosened up! The other seemed tight. I think it's good. Thanks!
Old 12-23-2013, 08:47 PM   #5
DIY staff
I like happy endings!!! You are welcome---
Old 12-23-2013, 09:43 PM   #6
Lord of Slums
Shut off only on cold side......
mj12 is offline   Reply With Quote
Old 12-24-2013, 02:32 AM   #7
And install a ball valve not a gate valve!
gregzoll (04-04-2014)
Old 04-04-2014, 02:19 PM   #8
Can you explain why only on cold side??
We're getting ready to replace one of our 2 50-gallon tanks ourselves and trying to learn all that's involved. One of the tanks started leaking last week so we drained it, and installed a shutoff ball valve on the hot side to isolate it and just be able to use the working one. It seems from reading here that this is not to code?
Alex+Kay is offline   Reply With Quote
Old 04-04-2014, 04:27 PM   #9
DIY staff
You only want a shut off on the inlet side---that way you can shut off the water if the unit needs servicing----
Two shuts is a hazard---and an unneeded expense---
One thing to look out for when installing a tank----be sure that the cold water line is going into the cold inlet----this may sound like a stupid thing to say---but the last guy might have screwed up---so check an make sure that what you think is the cold ,really is the cold-----
I just replaced an old heater---I warned the new home owner that the heater was very old---sure enough---I get a call two days after she moved in---Mike the water goes cool before I finish my shower----
Bad dip tube I figured---wrong---the tank was piped wrong---back in 1990--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
gregzoll (04-04-2014), jmon (04-04-2014)
Old 04-04-2014, 06:39 PM   #10
Funny story about a water heater.
The customer is a high school principle so you would think he had a clue.
He buys a 100 + year old farm house and wants me to come look at a bunch of jobs needing to be done.
I show up and there's a huge water heater sitting in a corner right in the kitchen with no walls around it.
Old steel water lines completely exposed running across the ceiling.
His question is "his insurance company wants to know if the water heater is more then 20 years old".
This thing was 6' tall and at least 5' wide. It had mercury switches for the thermostat.
It took 5 people, 2, hand carts and we had to cut out the doorway to get it out of the house.
The Following 5 Users Say Thank You to joecaption For This Useful Post:
gregzoll (04-04-2014), jmon (04-04-2014), oh'mike (04-06-2014), SHR Plumber (04-04-2014), TheEplumber (04-04-2014)
Old 04-04-2014, 06:52 PM   #11
Thanks for the reply, but another question...
The 2 tanks are in parallel - what is to stop the hot water from the good tank backing up into the empty tank, unless there is a valve there?
When our house was built eight years ago, the plumber connected one of the outside faucets to the hot instead of the cold water....
The Following User Says Thank You to Alex+Kay For This Useful Post:
oh'mike (04-05-2014)
Old 04-04-2014, 09:14 PM   #12
Retired from the grind
gregzoll's Avatar
Sounds like the Water Heater from the old Disney Movie "Snowball Express".
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 04-04-2014, 09:27 PM   #13
I replaced 2 50's recently, buy quality unions, the first 4 I bought were cheap ones and they leaked. Replaced with more expensive brand names and no issues.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 04-04-2014, 09:29 PM   #14
Lord of Slums
The reason the code exists is you would not want someone turning both shut off valves closed. That would basically give you a pressure cooker. In theory you would have the temp pressure valve to blow. If that valve were to fall, you could have big trouble.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 3 02-17-2013 11:24 AM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Dielectric Unions vs. Brass vs. None on Water Heater Perry401 Plumbing 2 05-07-2011 11:28 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
