Dielectric Union Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2012, 11:32 AM   #1
Dielectric union install
Hi there,
My cold water line for the water heater is copper and elbows left for the supply line. After the bend, it meets a galvanized pipe (the supply). There is heavy galvanic corrosion that I need to repair. I am planning to install a dielectric union. 2 questions: 1, do I have to do anything to the water heater itself, or is cutting off the supply line enough? 2, do I need to solder the copper pipe or can it be attached another way? (I have no experience with soldering nor have supplies for it. So if needed, any general instructions are very helpful!)
To summarize the entire system, PVC (with shut off) enters the house basement, meets galvanized, meets copper (corrosion) which runs to water heater.
pisbouts is offline   Reply With Quote
Old 11-28-2012, 11:48 AM   #2
Items wanted: Time
Rewards Points: 150
If you want to be a do it yourselfer better get some basic tools and supplies. Mapp torch, pipe cutter, sandpaper, flux, solder. And be prepared to keep ripping out galvenized pipe until you get to a good piece you can connect to.
NiNe O is offline   Reply With Quote
Old 11-28-2012, 12:08 PM   #3
Rewards Points: 13,300
You would be way better off getting rid of all that old steel pipe!
It is going to leak and close up on the inside at some point.
NiNe O (11-28-2012)
Old 11-28-2012, 12:51 PM   #4
Thanks guys. Would it be better to take out the galvanized and go from CPVC to copper? I know it'd be ideal to use one but I don't have the time for that major a project. Would a push fitting be okay to connect those two?
Old 11-28-2012, 02:51 PM   #5
Special User
Rewards Points: 1,230
Galv is a ticking time bomb. If you wish to avoid soldering, I would replace ALL the galv with CPVC (PVC is generally not allowed inside a home). Then you just have to transition from CPVC to copper at the water heater.
They do make push-fit gate valves (your water heater needs a valve on the cold supply, regardless). What I don't know is, can you push copper into one side of the valve and push CPVC into the other side? If so, that would seem to be the easiest solution, valve and transition all in one fitting without soldering.
tylernt is offline   Reply With Quote
Old 11-28-2012, 04:24 PM   #6
An old Tradesmen
Rewards Points: 6,548
Moved to Plumbing.
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Gas line union installataion diggerdave Plumbing 5 02-14-2009 01:59 PM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 11:16 PM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 10:07 AM
