Dielectric Nipple Rusting On The Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2013, 02:49 AM   #1
dielectric nipple rusting on the tank?
I had a liscensed plumber replace my gas water heater in august and everything has been fine but I just noticed today that the dielectric nipple that came with the water heater is rusting down at the base of the tank on the cold side. I dont see any water down there. The hot dielectic nipple looks fine. The water heater sits in my pantry and is vented. What's going on? I thought dielectric corrosion happened where two different metals meet? I attached a picture below. Thanks in advance!
Special_K is offline   Reply With Quote
Old 01-25-2013, 07:00 AM   #2
DIY staff
Rewards Points: 7,174
Your picture shows a standard galvanized nipple---the dielectric union would be attached to the top of that.
Call the plumber you have water leaking some where ----
Old 01-25-2013, 07:45 AM   #3
Rewards Points: 582
yep agree with mike...looks like a small leak at the nipple call plumber back have him redue that connection then it should be fine..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (01-25-2013)
Old 01-25-2013, 08:44 AM   #4
Roofmaster
Rewards Points: 2,172
Sure thats Galvanized? I see no Spangle. May be SS. Any anti-seize compound on that Nipple? Magnesium Anode?
Old 01-25-2013, 10:20 AM   #5
Rewards Points: 13,228
Simple way to check to see if it's the right nipple is to shut the water off open up a faucet to relive the pressure and remove the flex line from the nipple to see if there's a linner inside the nipple.
Old 01-25-2013, 12:25 PM   #6
Hey guys thank you all for replying. I got to thinking last night that those nipples didnt come with the water heater, I picked up a water heater hookup kit myself when i bought the water heater. The link to the exact product i bought is below. The old nipples and unions were rusted out so the plumber removed all of that back to the copper lines coming through the wall. Those nipples that came with the kit are indeed galvanized, a magnet sticks to them.
http://www.lowes.com/pd_148945-135-9...kit&facetInfo=
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Dielectric Nipple Replacement Question - Water Heater sicilian97 Plumbing 5 03-15-2011 11:15 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
