Dielectric Needed For SS To Cu? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2010, 11:57 PM   #1
Rewards Points: 190
Dielectric needed for SS to Cu?
Hi!
I'm going to be installing a water softener tomorrow. All my pipe is copper, and the part that gets connected to the softener (bypass) is stainless steel.
I've read a bunch of things...use a dielectric union, don't, only use it for galvanized....
So, is a dielectric used only for galvanized? Since I'm going from copper to stainless steal, it's not needed?
The instructions for the softener don't mention a dielectric and the place I bought it from shows it being directly connected.
thanks!
wiz561 is offline   Reply With Quote
Old 12-11-2010, 12:07 AM   #2
You are correct you do not need them for stainless to copper. However I would reccomend unions to aid in disconnecting. The choice is yours.
Work4living is offline   Reply With Quote
Old 12-11-2010, 12:54 AM   #3
FTRR
doesn't your softener come with its own manifold and gaskets? you should be fine if you follow the installation instructions.
FamilyTreeRemod is offline   Reply With Quote
Old 12-11-2010, 09:38 AM   #4
Rewards Points: 190
It's a Fleck 2510 with a SS bypass valve. The instructions show it just going from SS to copper, but wanted to get a second opinion.
Thanks!
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 11:17 PM
no ductwork needed to install a wall fan ? amakarevic Plumbing 2 01-22-2010 06:23 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
calculating amount of exhaust vents needed bitty071203 HVAC 4 06-09-2009 08:13 PM
