Did My Builder Screw Up Again? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2012, 01:00 PM   #1
Did my builder screw up again?
We are totally re doing our ensuite bathroom. There WAS a tub and a shower. We got rid of the tub and are having a large custom shower built. The shower has 2 independent shower heads. What I am worried about is that they capped the water lines from the tub and split the shower line to the 2 separate shower heads. Would I not have gotten a lot more water volume by using both sets of lines that were there instead of splitting one??
Prangsta is offline   Reply With Quote
Old 07-14-2012, 01:07 PM   #2
so you are saying that you are putting 2 shower valves? id make them feed each one seperate, a 1/2 inch line wont give you a lot of pressure with 2 of todays wasteful showerheads. wht do the installation instructions say about the water line requirements?
Old 07-14-2012, 04:00 PM   #3
yup, 2 separate valves. The heads are rated at 2.5gpm and I was told a 1/2 inch line gives about 5 gpm.. so we should have the minimum amount of water required.
I talked to my cousin, who is an engineer. He is pretty sure they would NOT have run 2 dedicated lines to the second story all the way from the basement and that it is likely a single line that was split it the wall or the floor below.
Thoughts?
Old 07-14-2012, 04:13 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 924
Thoughts?
If the 2 lines from the basement feed the whole bathroom then they are probably 3/4"- which is pretty standard. They probably branched 1/2" off to feed the tub.
It is not uncommon to feed two fixtures with 1/2" a supply
The Following User Says Thank You to TheEplumber For This Useful Post:
Prangsta (07-15-2012)
Old 07-14-2012, 04:18 PM   #5
liscenced electrician
Rewards Points: 538
why not do one control and a selector switch. That way you don't have two separate temperatures
jimmy21 is offline   Reply With Quote
Old 07-14-2012, 06:11 PM   #6
Not to get too personal, but we like our own temperatures.
Thanks everyone for the feedback.
Old 07-14-2012, 07:12 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
This is a more reasonable way to do it if you don't have a 3/4" line to feed two shower valves.
Journeyman Plumber
Help with Screw sizes needed! andyroo77 Building & Construction 5 06-02-2010 09:00 PM
stripped shower screw betsylwhs General DIY Discussions 2 12-28-2009 08:33 PM
How dangerous is two wires under one screw? Gigs Electrical 9 02-04-2009 06:44 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 03:27 PM
Screw and plug 5/4" PTP decking Klaus Building & Construction 3 06-10-2008 07:01 AM
