Old 12-01-2011, 03:44 PM   #1
Did I clog something? Septic Tank
I am a renter and have well water and a septic tank. That's what I was told anyway and I'm assuming it is accurate. This morning I flushed a few kleenex' which I have already learned I shouldn't do, and won't do again. I think I flushed 2 at a time, twice. The only thing that happened... is shortly after I had little to know water pressure. It has been about 6 hours with no change. Is this because of something I did or a random coincidence? Thanks for the help.
AUserName is offline   Reply With Quote
Old 12-01-2011, 04:54 PM   #2
Gbm
Sounds like a coincidence. I am assuming no water pressure anywhere - check for a tripped breaker (or burnt fuse) that controls the well pump If you can't find anything obvious then contact your landlord for instruction on getting a plumber or electrician out to troubleshoot. No reason to mention the Kleenex as that isn't that big of a deal. (The biggest no-no's are lady's sanitary pads etc. Those could clog but certainly will play havoc with the tank.)
Good luck.
Gbm is offline   Reply With Quote
Tags
clog, kleenex, septic, tank, toilet
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 08:58 AM
septic tank problems. littles Plumbing 1 02-24-2010 10:30 PM
Adding a roof over deck/patio, close to septic tank ncpaladin Building & Construction 0 02-21-2010 01:15 PM
Foul smell from abandon septic tank in house tsduncster Plumbing 12 12-19-2009 09:55 AM
