Old 07-22-2010, 04:59 PM   #1
Determine water heater specs from S/N
There isn't very much information on the labels on my water heater. All I have are energy ratings, the serial number, and that's its a Kenmore Power Miser 9. There is no model number. The Power Miser 9 series has several sizes. I want to figure out how many gallon it is, aside from guessing by size, how can i figure out its exact specs?
acerunner is offline   Reply With Quote
Old 07-22-2010, 05:24 PM   #2
lloydb's Avatar
Page 5 of the attached pdf should clear it up for you. Just measure your tank, find the measurements on the product spec chart and you'll be good to go
Binkstir
Broken Arrow hvac
lloydb is offline   Reply With Quote
Old 07-22-2010, 07:33 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Measure the circumference and the height and post back. 50 gal. would fit in a 10" dia.[31.4" circum.], 47" high tank according to the formula for the volume of a cylinder. Tank insul. thickness adds to these numbers.
Old 07-22-2010, 08:18 PM   #4
lloydb's Avatar
So sorry. I forgot to add the link... I went ahead an just took a screen shot. This is not guessing, measure the water heater and you'll know exactly what you have.
Broken Arrow hvac
Old 07-22-2010, 08:45 PM   #5
Owner
LateralConcepts's Avatar
Typically there's a code in the serial number also. The first 4 numbers should indicate the month/year or week/year
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 11:57 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
