detachable shower line from top of tub faucet
1K views 4 replies 4 participants last post by  md2lgyk
I need to attach the top shower feed line to top of tub valve so IF I need to remove or replace valve I can get it out without removing entire wall.
was pexing rest of plumbing in,,,do they make a pex swivel,,,that is like a hydraulic hose swivel???
#4 ·
this tub shower valve has threaded ips otlets on all four sides. No sweat copper in this house,,,will be all pex. Using brass pipe for tub spout. guess if they dont have swivel pex fitting I can use a compression fitting. or use pex and splice it later if necessary
NO hand held personal shower heads allowed here. Ever see what people spray? I want the water to stay INSIDE the tub
