Desiging A Manifold Water System? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-20-2009, 09:56 AM   #1
DIY = Done Right 1st Time
Desiging a manifold water system?
I have a 24x32 cape, 1 bathroom, full basement.
I recently ran a hot/cold water line from the water heater area to where my new front load washer/dryer are located. All is well.. and my plumbing job looks very clean/neat. Well.. That's about where that stops. The rest of the plumbing in my basement looks like a complete amateur installed it, and with the way the pipes were run I have one piercing through my 5 ply beam, tons of elbows that aren't needed.. and pipes that aren't secured well.
I was looking at going as far as cutting/capping the main cold water feed, and starting fresh. I know I could design a full copper system (running 3/4 to the water heater and trunk lines, then 1/2" to service ports), but running a pex style manifold system has my curiosity. I like the idea of running a nice cold trunk to where my water heater is. Tap the manifold for water heater feed, then run the output of the water heater to another manifold. That way I can have a central location for all shutoffs, and regulator.. and when I add my second bathroom upstairs I can just tag off the manifold.
Any feed back on this idea? I'm also looking to rerun some drain plumbing.. but that's another thread!
Anyone done a copper manifold installation?
BowDown is offline   Reply With Quote
Old 07-20-2009, 11:00 AM   #2
Quick Sketch...
need info on heating/hot water system please donaldcarter55 HVAC 1 07-07-2009 09:16 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 06:09 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
