Depth Of Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2010, 01:52 AM   #1
depth of water line
how deep should be in the mid west
southfoote is offline   Reply With Quote
Old 06-24-2010, 05:53 AM   #2
Check local code, 'midwest' does not narrow things down enough. The water/sewer lines need to be below frost line. In Minn. that can be over 4'.
Old 06-24-2010, 08:44 AM   #3
Owner
LateralConcepts's Avatar
At least 12" below the average local frost depth according to 2003 UPC Code. Check with your local building and planning dept. for depth.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-24-2010, 09:38 AM   #4
Owner
Just another thought - Because I'm an avid fisherman, and know ice fishing is popular in the mid-west...
common sense would tell me that a water line should be buried deeper than the ice is thick, in say late-January. So if you have to drill through 4' of ice to catch a Northern or some tasty Walleye's, your water line should be buried about 5'.
Lateral
(208) 818-8241
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
dishwasher water supply line options kenm09 Plumbing 2 02-11-2010 08:17 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
water line joint leak dtzulu Plumbing 4 05-14-2009 09:18 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
