Delta Tub Spout Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 10:51 PM   #16
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Oopsies,didnt check the date.
Looks like somebody else answered it today,I just look at newest posts when I get on here
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-16-2013, 03:33 PM   #17
Hey thanks for resurrecting this thread (pun?, haha)!!!
So after painting, updating all cabinet hardware, vanity lighting, faucets, and bathroom accessories (towel bar, toilet tissue holder, etc...) I am stumped on the tub shower faucet!
I spoke with Delta and they informed me that we could use in 13/14 series. So we purchased a porter series from plumbingdepot and i got the shower head/pipe on, valve cover and handle. Then I pull off the old faucet to have the same adapter as above!
I e-mailed I picture to Delta and they replied back "I apologize for the inconvenience you are having. However, we do have many different tubs spouts that are Venetian bronze and will fit this adapter. The tub spouts can be viewed on our website at www.deltafaucet.com. Once you are there, in the top right hand corner in the search bar, you will type "tub spouts". When the next page comes up, there will be multiple tabs at the top. You will click on the repair parts tab. From there you can view the numerous different tub spouts that are available. To view whether the tub spouts fit onto your existing adapter, under product features and benefits it will say "Sweat onto 1/2? C.W.T. or thread onto 1/2? IPS"."
My question is then will all delta faucets have that plastic piece in the back?! The Porter series did not! I have never sweated or soldered....
onuandrew is offline   Reply With Quote
Old 02-16-2013, 09:18 PM   #18
Rewards Points: 582
looks like someone soldered that adapter on... cause small piece of copper is sticking out of end ,.... just get new spout it will come with new adapter that you will not use.....but i would change o ring ...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-17-2013)
Old 02-17-2013, 01:00 PM   #19
Yeah Delta just confirmed that pretty much any 14 series faucet comes with the faucet and the adapter! We purchased the PORTER series from delta which delta confessed that was the ONLY ONE that didn't use the adapter....weird.
So hopefully within the next week I'll go to local store and just open one up in store and look at it.
Old 02-17-2013, 01:23 PM   #20
Solved!
after visiting home depot, reno depot, and any other depot I can think of and try to explain the problem to clueless plumb "assistance people" at these stores I came across this chatroom! Now I know I need to buy a new one and remove the brass adapter from the new spout (I still need to figure that part out) and then attach the new spout to the old soldered brass that is sticking out of the copper pipe... anyhow I found a temporary solution... to get the water pressure again of the shower head and to stop the lick and the annoying noise coming of the diverter when not working properly.
Got a cork from a bottle of wine left over from the night before, cut a 1-2 mm slice and push it against the diverter at the end of the spout! problem solved!
no more noise, water pressure back! cannot get easier than that
agaver is offline   Reply With Quote
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Bath tub spout leak issue abc Plumbing 1 01-26-2009 01:04 AM
Removing tub spout dummy14 Plumbing 20 11-17-2008 11:48 AM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
