Delta Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2013, 12:23 AM   #1
JoeRich's Avatar
Delta Tub Spout
I want to replace O-ring from a brass adapter that is soldered onto 1/2" copper pipe. What size O-ring should I buy? The Delta Spout is old and not sold anymore. I don't want to remove the O-ring until I get a new one. The spout leaks into tub when we use the shower.
JoeRich is offline   Reply With Quote
Old 08-01-2013, 05:16 AM   #2
Rewards Points: 13,446
Got a picture of this spout?
Not a plumber, but the only O ring I've seen in a tub spout is used to seal around the copper tubing to keep it from leaking down the back side toward the wall, nothing to do with it dripping out the spout on the end.
If you can get the o ring off just take it to any hardware or plumbing supply house and match it up.
JoeRich (08-01-2013)
Old 08-01-2013, 05:29 AM   #3
DIY staff
Rewards Points: 7,174
Call Delta----their service line is a good one---They can tell you and they just might sent you one for free----
Joe--Delta has a brass fitting that must be soldered to the copper stub out---very odd way to do a spout---but it does work well---
Old 08-01-2013, 06:25 AM   #4
Like this?
http://www.bing.com/images/search?q=...ectedIndex=317
Old 08-01-2013, 06:30 AM   #5
DIY staff
That one uses a set screw and an inside O-ring---the earlier ones were sweat on---I hated them----soldering in a finished tub and tile---what were they thinking?
Old 08-01-2013, 07:27 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
If it is leaking out of the spout as opposed to at the wall the o ring is not the trouble. The diverter has probably developed some scale and does not seal off as well as it used to. Lime-Away to the rescue.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following 2 Users Say Thank You to PoleCat For This Useful Post:
JoeRich (08-01-2013), TheEplumber (08-01-2013)
Old 08-01-2013, 06:54 PM   #7
JoeRich's Avatar
Delta Tub Spout
Thanks guys. The Brass Adapter with O-ring looks like thisDelta Tub Spout-spout-adapter.jpg. I'll try Lime-away.
Old 08-01-2013, 06:57 PM   #8
DIY staff
I'd just pop that off and head to the nearest auto parts store---they always have the best selection of O-rings
Old 08-01-2013, 09:29 PM   #9
Rewards Points: 1,852
If you need immediate assistance, call the Delta Help Line at 1‑800‑345‑DELTA (3358).
The Delta Help Line is available between 7 a.m. and 9 p.m. (CST), Monday through Saturday.
Read more: http://www.deltafaucet.com/customers...#ixzz2am6kHa9B
They will send you a new tub spout....
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
JoeRich (08-01-2013), oh'mike (08-02-2013)
Delta tub spout question natwin Plumbing 19 02-17-2013 01:23 PM
Removal of tub with delta roman spout, faucets John stockdill Plumbing 12 09-11-2012 09:12 AM
Delta Bath Faucet Leaks rtrinkle Plumbing 3 12-13-2011 07:44 AM
Removing Delta Roman Tub Spout stanart Plumbing 1 10-31-2010 05:20 PM
Delta Tub Spout Diverter ido1957 Plumbing 7 08-30-2010 09:16 PM
