Old 08-23-2009, 03:27 PM   #1
delta tub faucet leak
Hello,
our delta dual handle tub faucet continues to leak cold water.
we have changed the seat, spring, as well as stem unit on the cold side.
the leak persists.
what else could be causing the leak?
thanks
lnba is offline   Reply With Quote
Old 08-24-2009, 05:10 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
It may well just be leaking through slightly corroded threads of the seat. Take the seat out and wrap a flat wrap or two of teflon tape around the threads and see if that doesn't stop it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-24-2009, 07:11 AM   #3
Check the ball, they wear out or become grooved, or get scratched from debris in the pipes. And there is a tension adjustment in the ball cap, a large plascti washer with 4 notches in it. Tightening it, CW, puts more pressure on the cone washer.
Old 08-24-2009, 04:33 PM   #4
Thanks for suggestions...
the seat is rubber, so did you mean put teflon tape around the rubber piece?
also, as it has two handles, there is no ball within, unless I am mistaken?
Old 08-25-2009, 03:27 AM   #5
Long-Time DIYer
I'm not sure about your Delta, but most two-handle tub faucets have a stem with a rubber washer on the end that seals against a screwed in metal seat. That's what I was thinking about.
A Delta single-handle has a ball that can be adjusted against rubber seats on springs.
Don't know how yours is set up. Can you describe it a little more?
Mike
New Delta faucet drips KE2KB Plumbing 10 02-28-2012 10:34 AM
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 06:26 PM
Moen faucet leak doseph Plumbing 4 05-27-2009 01:29 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 09:33 AM
