Delta Showever Valve And Shower Head Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2010, 04:54 PM   #1
Rewards Points: 156
Delta showever valve and shower head leaking
Okay I just installed my new shower/tub valve and shower head. When I turn the valve on full throttle (hot) the water obviously comes out the tub spout but water also comes out the shower head as well but obvioulsy not a full power just fast trickling. I check the push rod on spout and it is down fully but I am out of ideas on what the problem is. I guess I could try and turn the main water pressure down just for those 2 lines as I did have that option but i would think that water pressure would not be the culprit. Any help would be great. .
ryan5068 is offline   Reply With Quote
Old 09-26-2010, 05:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 664
Did you use identical pipe material for both the head and spout?
Old 09-27-2010, 01:42 AM   #3
Rewards Points: 156
Copper from the valve to the shower head and then copper down to a gatorbite type fitting then galvanized out to the spout. Would this cause that to happen? I had no idea.
Old 09-27-2010, 08:18 AM   #4
Plumber
Rewards Points: 664
Just saying that a smaller ID pipe to the tub spout can cause enough flow retriction to divert some water out the shower head.
Old 09-29-2010, 04:16 AM   #5
Rewards Points: 156
well I guess I will try and turn the water pressure down a bit and see if that takes care of it. thanks I will keep you posted.
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 05:03 PM
shower faucet valve leaking throne7 General DIY Discussions 6 03-13-2010 06:31 AM
shower head and mixer valve on opposite walls scramble Plumbing 0 02-28-2010 12:50 PM
leaking hot water from the single valve kohler shower head B1026 Plumbing 2 01-11-2010 09:48 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
