Old 04-06-2009, 10:43 PM   #1
Delta shower valve body replacement
I bought a new delta shower trim kit. when I went to install the faceplate the mounting holes were different. The original holes were horizontal, and the new ones are diagonal. Do I have to replace the valve body?
Mdcinbad is offline   Reply With Quote
Old 04-07-2009, 05:52 AM   #2
Man of many hats
wrangler's Avatar
You may have the wrong trim kit. Many older Delta valves used 2 screws at the bottom (@4 & 8 o'clock) where the newer ones are located like your new trim kit @ 2 & 8 o'clock. Check to see if you can not find the right trim kit, but if the valve is old and you have access, it may not be a bad time to go ahead and replace it now and save the cost of the trim kit.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-07-2009, 11:38 AM   #3
Thanks for the response. Thats what I thought.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Shower Diverter Valve replacement twildey Plumbing 10 12-18-2008 10:43 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
