Delta Shower Cartrige ID! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2011, 06:54 PM   #1
I have a leaking shower that I assume needs a cartridgte replacement. Already tried 0-rings, and it was better, but no go. Only numbers I can find on it (other than ASSE 1016) are HG94282 and 078020E10490R01. Doesn't cross to anything I can find on Delta's website, or Brizo (who they turned the series over to a few years after this thing was apparently mfr'd... the casting says 2000). Any help would be higely appreciated!!
Last edited by Bartman79; 05-14-2011 at 06:56 PM. Reason: missed a digit in the part number
Bartman79 is offline   Reply With Quote
Old 05-14-2011, 07:05 PM   #2
If it is a delta, you should be able to take the cartridge to any decent plumbing supply house and they will probably have one. Or if you can post a picture that would be helpful.
broox is offline   Reply With Quote
Old 05-15-2011, 07:51 AM   #3
Delata uses those rubber cone washers behind and inside the cartridges. That is what causes leaks. Easy to replace and find(any home/hardware store).
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 06:45 PM
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 11:01 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 03:11 PM
