Old 10-30-2011, 03:31 PM   #1
Delta Monitor shower repair.
I have removed the set screw from side of the shower handle but her handle will not release from the cartridge. Any ideas??
Jakkkk is offline   Reply With Quote
Old 10-30-2011, 05:31 PM   #2
Persona Non Grata
VIPlumber's Avatar
You should be able to remove it by pulling straight back. Sounds like it might be stuck though, so a little twisting and turning while pulling backwards might to the trick.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Jakkkk (10-30-2011)
Old 10-30-2011, 06:30 PM   #3
Sometimes I wedge a crescent wrench between the handle and trim kit and wiggle it around. If it turns open and closed put something behind it with it open and shut the handle to force it off. Use electrical tape to not damage anything.
kindwon is offline   Reply With Quote
The Following User Says Thank You to kindwon For This Useful Post:
Jakkkk (10-30-2011)
Old 10-30-2011, 08:25 PM   #4
Thank you for your replies. I have tried the methods suggested with no luck. I can't get the handle to budge.
Old 10-30-2011, 08:55 PM   #5
Persona Non Grata
VIPlumber's Avatar
Seems like we're missing something simple here. Which model do you have? Maybe try a little squirt of lubricant to loosen it up.
Old 10-30-2011, 09:08 PM   #6
I agree about something simple. But, I have tried WD40 etc. No Luck!
Old 10-30-2011, 09:46 PM   #7
It it the one with the separate temp and flow levers. If so did you pop off the temp lever cap. Then remove the screw that holds the pressure lever on. Site you did just don't know. Worse comes to worse break the handle, the cartridge isnt too much.
Jakkkk (10-30-2011)
Old 10-30-2011, 09:53 PM   #8
Thanks kindwon-
It's a single lever. The cartridge expense is not the issue. The only way that I can see to get the handle off is to cut it off. That means replacing the handle + the trim kit + the cartridge. The works!
Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? spyboy Plumbing 10 03-09-2012 08:25 AM
Delta SH faucet repair Danny3129 Plumbing 0 07-17-2011 12:06 PM
Delta faucet repair? kbsparky Plumbing 5 04-18-2011 07:31 PM
Repair Instructions for Delta Kitchen Faucet BigJim Plumbing 2 04-07-2011 11:36 AM
Delta 10in table saw repair GillesLam Building & Construction 3 03-21-2009 05:19 PM
