Old 07-16-2012, 11:22 PM   #1
Exclamation
Delta / Moen faucet sink hole size minimums
I just stopped installing a Moen Anabelle single handle high arc faucet in my older stainless steel sink. Why?
  • It was tall and unstable with the mounting hardware included.
  • My other concern was the scraping of the integrated supply lines from the center sink hole. I measured the sink hole -- it's 1 3/8". Since the spec information isn't included in the box, I checked the Moen website. The minimum sink hole size is 1 1/2".
Now that I have to take this Moen back, my options are limited. I'm checking the Delta faucet specs, and their docs indicate that they can be installed with holes measuring 1 5/16" to 1 1/2".
Has anyone found the Delta faucet specs above to be inaccurate?
nthdegreeburns is offline   Reply With Quote
Old 07-17-2012, 08:06 AM   #2
I have been using delta faucets for over 30yrs never had the problem your talking about...also never had any trouble getting faucets to mount to any top....but to answer your question if they say it will install ..it will .....they have a pretty good tech service....ben
ben's plumbing is online now   Reply With Quote
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (07-24-2012)
Old 07-17-2012, 09:43 AM   #3
I'll give 'em a try then. Moen's website explicitly states that the minimum hole size for their Anabelle high arc single handle faucet is 1.5".:
http://www.moen.com/shared/docs/prod...ns/87650sp.pdf
Our sink holes are right at 1 3/8" in diameter. It sucks, 'cause I really liked the faucet....
  • I was able to get all the lines through the hole, but their bulk shifted the faucet to the left by about 1/2".
  • The lines were pressed right up against the sharp edge of the stainless steel.
  • Finally, the mount, on a thin gauge stainless steel sink, was less than sturdy for something that tall.
The Following User Says Thank You to nthdegreeburns For This Useful Post:
ben's plumbing (07-17-2012)
Old 07-17-2012, 10:21 AM   #4
Doing it myself
Alan's Avatar
[*]I was able to get all the lines through the hole, but their bulk shifted the faucet to the left by about 1/2".
If the required hole is 1.5 and you have 1-3/8 holes, your math is off.
Seriously though. I hate when they start making things non-standard like this. It causes all kinds of problems.
What happens when Joe decides to grind his stainless steel hole out another 1/4" and then a year later the faucet takes a dive, and he decides to replace it with a different style, and the mounting hardware won't work because the hole in his sink is too friggin big?
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
jaydevries (07-24-2012), plummen (07-18-2012)
Old 07-17-2012, 10:42 AM   #5
Yeah -- minimum of 1-1/2" -- I can shove all the feed lines into the 1-3/8" hole, but the fit is too tight to finish the work. I guess Moen's spec allows for room to work / position the faucet. Right now, I have zero clearance and room to position things correctly.
Note -- all this talk about holes and shoving -- there's a dirty joke in here somewhere.
I thought about this too -- I talked with the wife about expanding this ever-growing repair into replacing the sink too. Lucky for her, she already hated the Moen faucet anyway, so it'll all be going back to Lowe's where I'll find a Delta with broader tolerances.
Old 07-18-2012, 07:30 AM   #6
retired elect/hvac/plumb
plummen's Avatar
I like simple faucets,but thats also why I let customers pick their own.
As Henry Ford used to say "Any faucet any style as long as its a Moen"
True story!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-24-2012, 04:59 PM   #7
***UPDATE***
Ended up going with a Delta Leland Pull-Down stainless steel model. Fit the odd 1 3/8" sink holes without a hitch. Hated to spend the extra $$$ on Delta (the Moen felt more substantial), but incompatible hole fittings screwed that pooch.
Old 07-24-2012, 08:46 PM   #8
***UPDATE***
good deal hope it works well and remember "DELTA" were 1st because we last...
Old 07-24-2012, 09:52 PM   #9
plummen's Avatar
"Delta in Quality out"!
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (07-24-2012)
Tags
moen delta sink faucet
layout and floor hole placement for kit sink firsthomereno Plumbing 2 04-27-2012 06:25 PM
Low Pressure from Moen faucet tsperry Plumbing 1 12-08-2011 06:11 AM
Moen kitchen sink issues. (Pictures included) Largest Plumbing 2 12-02-2011 05:34 PM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Moen faucet leak doseph Plumbing 4 05-27-2009 01:29 PM
