Delta Faucet Repaired But Keeps Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2010, 03:53 PM   #1
delta faucet repaired but keeps leaking
Hello out there! I recently repaired a Delta single handled kitchen faucet. Washers, springs, o-rings, cam washers etc. Problem is it works for a few hours and then starts leaking out of the spout. Real bad! I have taken it apart and reseated everything with the same result. What baffles me is that if everything was not seated right to begin with it would start leaking right away but it takes a while. Any thoughts?
thanks
bigdukesix is offline   Reply With Quote
Old 01-27-2010, 01:16 AM   #2
replace the shaft with the ball on it also try stretching the springs a little to put more pressure on those rubbers
plumbdoc is offline   Reply With Quote
Old 01-27-2010, 06:06 AM   #3
also replace the ball. There is a plastic nut(top ball washer) on top with slots for a spanner, that will put more pressure on the ball.
New Delta faucet drips Ultrarunner2017 Plumbing 10 02-28-2012 09:34 AM
Delta Shower Faucet and Valve- plummer botched? twanto Plumbing 3 08-08-2009 08:04 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
