Delta Faucet Repair? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2011, 04:05 PM   #1
Electrical Contractor
kbsparky's Avatar
Delta faucet repair?
I have a 20+ year old delta single handle type faucet in my shower. Lately, the shower head still drips even when it's turned off.
I understand that they might be some sort of repair kit for this sort of thing? A ball with holes in it and/or some o-rings?
Is that an easy repair to perform, or should I scrap the whole thing and start over?
-KB
Old 04-15-2011, 10:29 PM   #2
It's probably got some life left in it yet. If it was me, I'd repair it. Kit couldn't be more than $5-10.
Which Delta do you have? Maybe a pic could help us figure it out.
VIPlumber is offline   Reply With Quote
Old 04-16-2011, 06:36 AM   #3
If a shower only fixture, no tub spout, rebuilding may be a solution. They are easy to repair once you get past the handle fasteners, usually a set screw long ago corroded/rusted tight.
If there is a tub spout, it is likely not the valve leaking unless it comes out the tub spout, just water sitting in the shower head dripping.
Old 04-16-2011, 07:28 AM   #4
kbsparky's Avatar
This is a shower, no tub faucet involved. The dripping continues all night, leaving a trail of water into the drain, so this is not simply the shower head draining.
Here is a pic of the fixture:
-KB
Old 04-18-2011, 07:29 AM   #5
kbsparky's Avatar
bump.
-KB
Old 04-18-2011, 06:31 PM   #6
I have a couple of these Delta faucets (circa 1987) and the standard Delta repair kit at Home Depot or Lowes should work fine... you can buy the kit up front and then try the repair or disassemble your valve and bring the parts to Home Depot or Lowes to match them to a kit... AND be sure to shut off the water before taking the valve apart!!
billyjoe is offline   Reply With Quote
Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? spyboy Plumbing 14 05-13-2014 07:03 PM
New Delta faucet drips Ultrarunner2017 Plumbing 10 02-28-2012 09:34 AM
Repair Instructions for Delta Kitchen Faucet BigJim Plumbing 2 04-07-2011 10:36 AM
Delta faucet nightmare Ultrarunner2017 Plumbing 4 03-11-2011 10:49 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
