Old 11-04-2009, 03:46 PM   #1
Delta 1400 shower wont turn off
Our shower will not get hot water nor will it shut off completly. I turn the handle both ways and it just stays on. I can get it to stop if I hit just the right spot but this is difficult. I took the handle off and found the white plastic thing with groves as well as the metal thing, they both look like there in good condition. Next I took off a little black oring thing it looked good as well. There is a white piece with a stem sticking out of it, but the stem dosnt seem to come off it just keeps rotating around when I put a wrench on it. Help! I'm a mom that needs a bit of guidence without calling a plumber to come out, just not in the budget right now. All help is welcome - Thanks in advance
asherwood1 is offline   Reply With Quote
Old 11-04-2009, 07:29 PM   #2
The cartridge is worn out. I suggest that you take a picture of the valve(inside the wall-after you have removed the chrome trim)
Take that picture to a real plumbing supply store. Explain the problem to the pros at the counter.
The chances are good that they will recognize the valve and sell you the correct replacement cartridge.
They should be able to instruct you on the installation and even give you an illustrated instruction sheet.
The job is simple---However----If you screw it up you will need to call a plumber.-MIKE--
Old 11-04-2009, 08:03 PM   #3
THANK YOU!, I will try that tomorrow, please cross your fingers for me
Old 11-05-2009, 12:46 AM   #4
If you are sure its a 1400 series then the cartridge is very easy to get. Just be VERY careful removing the nut that holds it in place. don't grab it too tight, Try doing it by hand first. also don't forget to turn your water off first to the house.
plumber Jim is offline   Reply With Quote
Old 11-05-2009, 08:16 AM   #5
Is the Nut the metal ring that is holding the white thing with the stem in place? I tried to get it off by hand but it is stuck in place, do you think it was placed on with some type of adhesive? I'm not sure how I'm going to get it off but the metal/copper ring thing is holding the white thing in place. Ugh wish it could be easy - never is!
Old 11-05-2009, 11:11 PM   #6
thats the nut you need to get off. be VERY careful.
More On This Topic
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
Hi everybody, my name is J and I'm talking to you on behalf of Expert Village. I'm going to show you how to pick mushrooms guys. There are a lot of different types of mushrooms as you all know. These type of mushrooms, crimini mushrooms are small light... Read More »
How to Remove a Shower Head
How to Remove a Shower Head by Expert Village
Hi, I'm Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, today I'll show you how to clean a shower head. The first thing you need to do when you lose power from your shower head is to carefully remove any structures that you may have... Read More »
Today we're building a plant basket from live plants. We've chosen our plants. We've chosen our basket. We've got our liner in our basket. And now we're going to somewhat prearrange the flowers. We want the handle of the basket to be right down the... Read More »
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 9 02-06-2010 11:20 PM
removing Delta 1400 cartridge toe-fu Plumbing 1 09-24-2009 11:54 AM
Delta Shower Faucet and Valve- plummer botched? twanto Plumbing 3 08-08-2009 09:04 PM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 03:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
