Old 04-27-2012, 10:02 AM   #1
Delta 1400 Seriers Shower Single handle faucet
Hello, I have a Delta 1400 series shower faucet and I have adjust the scalding control but still don't get the hot water to maintain. It starts hot for about 4 or 5 seconds then goes back to luke warm. Does anyone know what the problem is and how to maybe resolve it. thanks
tcamp123 is offline   Reply With Quote
Old 04-27-2012, 10:17 AM   #2
Doing it myself
Alan's Avatar
It kind of sounds like something is crossing over nearby.
Do you have this problem anywhere else in the house?
Journeyman Plumber
Old 04-27-2012, 11:59 AM   #3
No, but when we turn the faucet on the the sink , same bathroom , the shower gets hot again, weird. Thank you for taking the time.
Old 04-27-2012, 12:01 PM   #4
Their is a circulating pump on the system as well, didn't know if that has something to do with it?
Old 04-27-2012, 10:35 PM   #5
Doing it myself
Alan's Avatar
I'd be willing to bet in this case, that your check valve on the recirculating line has failed. When you turn on the shower, the incoming cold water is taking the path of least resistance (shortest distance of piping) and going past your failed check valve and through the return line to the shower. I'm guessing that your lavatory is further upstream on the recirculating line and turning that one on pulls hot water through the hot water line.
That's what i'd check anyway.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
tcamp123 (04-30-2012)
Old 04-28-2012, 02:00 AM   #6
A shower faucet is called a "shower body". This shower body has an internal cartridge called a "pressure balance". Replacing the pressure balance cartridge with a replacement 1400 series cartridge will solve the problem.
PlumbDumb is offline   Reply With Quote
The Following 2 Users Say Thank You to PlumbDumb For This Useful Post:
jaydevries (04-28-2012), tcamp123 (04-30-2012)
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
Delta Shower Faucet and Valve- plummer botched? twanto Plumbing 3 08-08-2009 09:04 PM
Kohler single handle shower randy717r Plumbing 1 03-29-2008 12:35 PM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 09:08 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
