Deep Well - Wiring Control Box And Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2007, 12:46 PM   #31
Roy
Did you get your wiring issue fixed?
Roy is offline   Reply With Quote
Old 12-10-2007, 02:21 PM   #32
Still working on it. It's been too cold (-30) to be crawling around down there + I've been busy at work... Today is my day. I changed all the wiring, but now, for some reason, I have no power from the switch to the control box! I will have to go down and check my connections, but FIRST I must watch Days of Our Lives... lol
Later that day...
OK - I checked all connections. Power going into the switch - none coming out. ?? I wired it like the original diagram (previous attachment) EXCEPT I now have a neutral (W) coming from the panel. I grounded this to the pressure switch box along with the ground (G) wire. Coming from the pressure switch, I ground W and G to the control box, hooked R and B into line 1 and 2, and hooked up the R,Y,B as before. Everything is now 12 gauge.
WTF? I'm just about ready to brush the cobwebs off my wallet...
Fix-It Chick is offline   Reply With Quote
Old 02-27-2008, 04:13 PM   #33
Well well well. I'm back. As you know, I tried absolutely everything I could think of, much to my frustration. It finally got too cold to work down there, so I left things the way they were... just kept flicking off the breakers whenever I remembered. Finally got a warm weekend, so here's what happened...
I'm sure you'll all get a kick out of this.
Pulled the pump to check the wiring and guess what? The 3/4 HP 3-wire pump that they sold me (so the receipt says anyway) is actually a 1/2 HP 2-wire pump! WTF!?
I didn't check it against the receipt, I just gave it to the guys to install. They didn't know 2-wire from 22-wire... they just hooked it up. There was some confusion as to where to connect the green wire from the pump, because as I said, the original installation was old - no ground - and only R,B,Y were running from the well to the house. So, they told me they had grounded it inside the well...
I have been trying to hook a 2-wire pump to a control box and wondering WHY IT WON'T WORK!
So, as I figure it, there are 2 lessons to be learned here:
  1. Double check your merchandise against the receipt.
  2. If you're not sure, double check new equipment against old.
Arrrggg!
Anyway, just thought you might get a laugh out of that. Thank you all for your suggestions, which I'm sure would have fixed the problem, IF I had the right pump.
Old 08-22-2008, 01:13 PM   #34
Does anyone know what a ''Null Line'' would be on the control box?
haulinhp is offline   Reply With Quote
