Deep Well Submersable Chedk Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2012, 09:33 AM   #1
Deep well submersable chedk valve.
My well pump pressure drops from full 50 lb. pressure to the 30 lb. cut on pressure about every 3 minutes. I have checked the bladder tank, and all water lines in and under the house and found no leaks. As fast as the pressure bleeds down I suspect the well check valve. If that is the case can I install an upper check valve so I do not have to have the well pulled.
passionrecordin is offline   Reply With Quote
Old 12-27-2012, 09:36 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How deep is your well?
Putting a check valve on the system will alleviate the pump turning on and off so frequently, but if the water leaks out of the rest of the piping, you're going to have air coming into the system every time you use water. The amount of course depends on how much pipe is in the well.
This all assuming that you don't have a leak in the line somewhere though. If you install a check valve near the well, that should help you figure out where the problem is.
Journeyman Plumber
Old 12-27-2012, 07:00 PM   #3
Rewards Points: 196
Sounds like same problem I had.We pulled the pump out of casing and found old steel riser piping rotted out in the first 10 ft out of pump.Pipe looked like someone shot it with bird shot.
HVACTECH96 is offline   Reply With Quote
Old 12-27-2012, 09:26 PM   #4
Rewards Points: 582
the proper way it to pull pump ..check piping,and check valve on pump..may be time to replace ..pump... pending on its age...ben sr
Backwater Valve Installation CCCron Plumbing 2 10-24-2014 09:52 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
