Deep Well Pumps - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2009, 05:07 PM   #1
deep well pumps
i have a deep well pump vertical i changed the pressure switch and gauge . comes on and off ok builds up pressure as soon as the pump cuts off gauge falls to zero......... can someone tell me whats going on with it???? . thank you russ
janie31312 is offline   Reply With Quote
Old 06-06-2009, 05:40 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
After the pump there is usually a check valve and if its deep there may be one close to the to of the pit.
It seems that the check valve may have messed up or you may have a leak between the check valve and the gauge
Old 06-06-2009, 06:44 PM   #3
If the pump comes on and the pressure immediately goes to cut off pressure then drops immediately to 0 it sounds like your bladder tank or pressure tank is water logged.
hayewe farm is offline   Reply With Quote
How hard is your water? How deep is your well? brokenknee General DIY Discussions 10 05-05-2009 07:17 PM
Concerned About Deep Hairline Cracks jecop General DIY Discussions 7 04-17-2009 04:39 AM
New Deep Tub ~ Needed Raised Deck .. Faucet for Deep Deck? Hisgirl Plumbing 1 01-17-2009 11:00 AM
Grinding stump but how deep are gas and electric lines buried? jbk Landscaping & Lawn Care 1 08-02-2008 11:46 AM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 09:35 PM
