Old 01-28-2010, 12:48 PM   #16
Water quality'n pump guy
Deep well pressure tank
Originally Posted by Driller1 View Post
Well water should never be dirty. Never.
This is how to develop a well. Note the clear cup in the man's hand?? He will not move the rig off the hole until the water is clean.
This is an existing older well, not a new one and... the question was about a pressure tank.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 01-28-2010, 03:55 PM   #17
Are you a mod on here now??? Or, just pushing your opinion in??
The word is NEVER, new or old.
user69544 is offline   Reply With Quote
Old 01-28-2010, 03:59 PM   #18
Originally Posted by meboatermike View Post
The well actually has a 6" ? well casing not, certainly not 2". Hit ledge at 3 feet or less. And yes, mine is quite deep and yet the neighbor just up from me had one drilled a week after mine and only went like 50' with way more water. We originally had dug wells almost across the street from each other and were both close to running out on dry summers. Still have not regretted putting in the deep well even though I might have waited had I known he was going to stop using his dug well.
I am glad it is not 2". We can not drill 2" in Michigan. They just do not like them at the DEQ. Mostly because once they are hooked up, to re-chlorinate them, the drop pipe has to come out.
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 05:49 PM
New tank new pump, no pressure?? Toyz Plumbing 2 07-26-2008 08:38 AM
pressure tank problem? steel Plumbing 14 07-03-2008 03:06 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
