Deep Well Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2012, 08:43 AM   #1
deep well pressure switch
A friend put a pressure switch in for me but I guess it is not wired correctly as the pump doesn't shut off. I have to unplug the power to shut it off. Wiring instructions that I've looked up talk about 4 wires coming out of the pump, but I only have 2 (black) wires coming out of my pump. Wayne Deep Well Model CWS50. Currently it's wired with the power wired to the 2 middle contacts and each of the wires coming from the pump wired to the outside contacts. Anyone have any suggestions?
crazyhorse3629 is offline   Reply With Quote
Old 04-15-2012, 10:32 PM   #2
Rewards Points: 582
look at pressure switch...4 contacts...2-marked line..these come from breaker....2- marked load...lines from pump.... I think you are wired wrong....but ckeck me as stated ... outside contacts are line...inside are load...
The Following User Says Thank You to ben's plumbing For This Useful Post:
crazyhorse3629 (04-16-2012)
Old 04-16-2012, 01:41 PM   #3
pressure switch
Thanks for the response. Actually I went to Menards for other things and looked at how the pressure switch was wired on a pump they had on display. You were right, it was wired wrong. I came home and wired mine the same way as the one at Menards - the 2 black wires from the pump to the 2 middle contacts and the power line to the 2 outside contacts. Still have the same problem - it doesn't shut off. Now I'm wondering if it's the little tube running to the switch. It was copper tubing and he jury rigged it to use plastic and put hose clamps at each end. So possibly it's not a tight enough seal. I'm about ready to just buy a new pump.
Old 04-16-2012, 02:03 PM   #4
Civil Engineer
Rewards Points: 4,514
The "little tube" running to the pressure switch is the pressure tube that transmits the pressure reading to the switch. The pressure tube cannot function correctly if it is gummed up with debris, which is not uncommon. Usually I replace the tube when I replace the pressure switch. If the pressure tube is the problem, then replacing the pump will not solve the problem.
It is also possible that the pressure switch was damaged due to the initially improper installation.
Old 04-16-2012, 06:49 PM   #5
Rewards Points: 616
has the pressure take been checked to see if bladder is good and set to correct pressure to coordinate with pressure switch
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 04:51 AM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 08:53 PM
Pressure switch ratings gp_wa Electrical 6 08-31-2009 10:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
