Decreased Water Pressure In Bathtub/shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2012, 07:28 PM   #1
Decreased water pressure in bathtub/shower
I have well water and my bathroom plumbing is of 1990. I just back washed my shower head and it helped my water pressure momentarily. Sediment is a problem, some came out. (I am unable to back wash my faucets because they are in the wall and do not extend into the bathtub). A plumber repaired this problem before by cutting and soidering the mixer to clean it out. I do not want to call him back. Is there an alternative repair for an ongoing problem?
Georgia Dawg is offline   Reply With Quote
Old 01-01-2013, 06:56 AM   #2
DIY staff
Rewards Points: 7,174
Often ,simply removing the cartridge ---cleaning the valve body with a light sanding --then a new cartridge and you are back in business---
With your sediment and lime /iron condition---deliming the valve body might be a good idea---lime-away or a commercial steam table cleaner would be a good choice.
Delta mixers have a small screen inserted into one of the back holes in the valve body---cleaning or replacing that is also needed.
Old 01-01-2013, 08:31 AM   #3
Rewards Points: 13,724
Old steel pipes?
No water softner?
What do you mean by back washing, and how are you doing it?
Whens the last time you drain the sediment out of the water heater?
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 06:52 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 18 08-08-2010 02:09 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
