Deck Mounted Pot Filler - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2009, 01:34 PM   #1
Deck mounted pot filler
Installing a deck mounted pot filler beside our stove. Between said counter is a 6 ft counter, a dishwasher, and then the sink with the pumbing. So I'd have an 18" (under the sink), plus 24" plus 6 ft, swing the corner to the far side of an 18" counter run to pumb. Can I couple stainless flex hose, or do I have to run copper to the last 18" and then use flex hose to attach to the filler itself? I need to be able to move that last 18" cabinet now and again so I don't want to anchor it with hard plumbing.
Thanks Relle
Rellie25 is offline   Reply With Quote
Old 12-13-2009, 06:18 PM   #2
Remodeling Contractor
just connect with PEX...cheaper and easier.
Old 12-14-2009, 07:28 AM   #3
Talking
PEX it is!
thanks so much. Don't know if its in our code books in MA but that's what I'm putting in. Who says you can't have good, fast, and cheap! Thanks again. (to the tune of I'll be home for christmas) I'll have my pot filler for Christmas ... Great
Old 12-14-2009, 02:11 PM   #4
PEX has been allowed for use in MA for 3 or 4 years, now. Just make sure you get PEX that's approved for potable water - you can't use the heat PEX.
Ishmael is offline   Reply With Quote
Old 12-14-2009, 03:12 PM   #5
Potable water it is then!
So much accurate fast information. Thanks so much.
Old 12-14-2009, 03:14 PM   #6
Special tool for PEX
I assume that PEX requires special fittings? Special tools??? (So I don't get taken when I go to the store)
Old 12-14-2009, 04:17 PM   #7
you need a crimping tool. Supply houses will rent one or use a sharkbite fittings for the little work you are doing. These simply slide onto the pex and to the existing copper or CVPC lines you have now and you are done.
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 07:57 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
