Old 01-17-2008, 07:51 PM   #1
Decided on PEX Should I use Clamp or Expansion?
I have been trying to choose the PEX system I want to use. I don't have a lot of line to run but I was wondering which system is better and easier to use in tight places Clamps or Expansion (Wirsbo)? Thanks.
twilightcall is offline   Reply With Quote
Old 01-17-2008, 08:48 PM   #2
Send a message via AIM to Marlin
Wirsbo is easier to use in small spaces as you don't have to work the crimper in there. I also regard it as a superior system to the crimp rings. I can't make any promises on the quality of any pex system though.
Marlin is offline   Reply With Quote
Old 01-18-2008, 05:09 PM   #3
Ok thanks. The tools seem to be the expensive part of Pex. I will probably go with Wirsbo since I can get the tool on Ebay for about the same as the crimping tool from Home Depot and most of the pros I spoke with like Wirsbo. Does anyone have experience with both? Thanks.
Old 01-18-2008, 05:11 PM   #4
I've used both and you already have my opinion. The Wirsbo tool ($280) is a lot more expensive then the crimp tool ($90). You can buy the Wirsbo tool then sell it again and recoup most of your money but I'd hold onto it, it may come in handy in the future.
Old 01-31-2008, 09:07 AM   #5
AbeBarker
Do you know any of the inferior qualities the crimping system may have?
AbeBarker is offline   Reply With Quote
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Expansion Valve Stuck Closed JustinD HVAC 3 08-31-2007 05:59 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 06:44 AM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
