Death Trap Shower On My Recent Trip To Honduras - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2009, 09:17 AM   #1
Rewards Points: 156
Death trap shower on my recent trip to Honduras
I lived to tell the tale of showering under this sucker. I don't know what was worse, the mold or the instant water heater.
jayp is offline   Reply With Quote
Old 04-06-2009, 09:35 AM   #2
RippySkippy's Avatar
Holy Hot Water Batman...that's just not right! Never seen anything like that before...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-06-2009, 10:13 AM   #3
NIce water heater
Old 04-06-2009, 10:42 AM   #4
Rewards Points: 498
That must have been only a four-star hotel. lol
gma2rjc is offline   Reply With Quote
Old 04-06-2009, 11:13 AM   #5
Rewards Points: 156
haha
These things are really common all over Central America. People typically do not have hot water nor the capacity to keep water hot in a heater. This is pretty much the household standard and they're usually installed by untrained people. Even when they're installed relatively safely, there's still a chance of short circuit right down to your toes!
Old 04-06-2009, 12:13 PM   #6
I imagine if the incoming water is between 70-90 it should work pretty good. That must be tied into a GFCI breaker
Or another GFCI outlet in the room
I wouldn't mind having something like that on an outside shower
Have a picture with a better pic of the name?
Found one online:
http://www.emarket-usa.com/anuncio-6...a-Phoenix.html#
Simpler setup than with a water heater. Less to go wrong and
easier to install and maintain. 220 volts 3200 watts min, 5400 watts maximum.
Great for installing in your cabin ! The unit will operate properly with lower water
pressures commonly found on Boats and RV's.
I'm planning an outdoor shower fed thru a solar water heating setup
So this would only be a booster if needed
Another online pic of an installation :
The owner is an electrician by trade, so it is properly installed.
First of all, let me say that I really don't have any idea how the darn thing works. It has a couple of coils of heater wire inside the head which obviously heat up, but I don't know what makes it go on or off. I don't touch the controls, because it shocked me when I did.
Old 04-06-2009, 12:34 PM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
I've heard some of those third-world countries have horrendous jails! But I thought things like that were outlawed by the Geneva Convention?
Man of many hats
wrangler is offline   Reply With Quote
Old 04-06-2009, 12:42 PM   #8
Rewards Points: 156
that's it
That's it -- the Lorenzetti. The locals call it the "widow maker." The sailboat crowd are usually familiar with them too because it's fairly common on boat...especially European ones. They do work but you have to learn how to tweak the water spigot just right to make it last. Most of the time they kinda pulse between hot and cold.
Old 04-06-2009, 12:44 PM   #9
Rewards Points: 156
here's a link
http://www.lorenzetti.com.br/
It's all in Portuguese though...
Old 04-06-2009, 12:44 PM   #10
Man of many hats
wrangler's Avatar
Rewards Points: 354
Hmmm... sounds a bit like a coffee maker. Will it do tea as well?
Man of many hats
Old 04-06-2009, 01:51 PM   #11
Registered User
Termite's Avatar
Probably not, but it could turn you into toast!
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Shower trap leaks Kiwi DIYER Plumbing 1 08-30-2008 05:58 AM
