Dealing With Iron Bacteria Stricken Water Softener, Advice? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2009, 03:27 PM   #16
Rewards Points: 150
I am not sure of depth, this house was a foreclosure so there are quite a few mysteries I have worked through so far.
I was told that I would need to open the petcocks on the front and rear of the house for about 8 hours to purge the system. Half open and running for 12 or so hours is more logical. I was afraid of burning out the pump by running it at 100% duty cycle essentially.
We have company in town this weekend and the following, so Ill do it after that. I can also build a pressure tank out of a 5 gallon bucket and use my air compressor to force the fluid down the hose and into the well.
This should be interesting, Ill no doubt ruin at least one set of clothing LOL.
Evan
240sx4u is offline   Reply With Quote
Old 03-07-2009, 03:45 PM   #17
GC/Master Plumber/Mech
Rewards Points: 560
Can you post a pic of the pit
Old 03-07-2009, 04:34 PM   #18
Rewards Points: 150
Its raining like crazy here right now. Ill try to sneak out tomorrow and get some pictures when it lets up. Ill snap some photos of the pressure tank etc.. as well.
Evan
Old 03-11-2009, 09:02 PM   #19
For a water softener contact a watercare dealer. Watercare.com
They will know what you are talking about and beable to help you out alot better than culligan. I think there names are Gibsons or Ensings. Not sure which one is closer. Ask for the caredoft line of softeners they are the best on the market.
lilh2o3 is offline   Reply With Quote
Old 03-11-2009, 09:05 PM   #20
Rewards Points: 150
Sorry I haven't followed up! I have been sicker than a dog and been dealing with damage control at work.
Evan
Old 03-16-2009, 11:32 AM   #21
Rewards Points: 150
The moment you all have been waiting for, photos. I think I can see iron bacteria scum in the well. Ill be doing the shock this coming weekend. Should I run the faucets to shock the pipes in the house along with the pressure tank etc?
Thanks!
Evan
Old 03-17-2009, 03:56 PM   #22
Water quality'n pump guy
You have steel casing and a brass pitless adapter and it looks like you have a 3 wire pump with an above ground control box because of the 4 conductor cable; 2 hots, a start and a ground wires.
IRB (iron reducing bacteria) is made up of numerous types or aerobic and anaerobic bacteria that live in and under water in and on the earth. They are harmless but produce slime and encrustations that can reduce well production. They can produce odor problems and they can colonize a softener etc.. You can sanitize the softener with like a half cup of bleach and a manual regeneration stopping it in the Brining position for like 15-20 minutes and then plugging it back in and allowing it to finish on its own. DO NOT MIX bleach with any type of resin cleaner like Iron Out etc..
Shocking a well cab cause serious pump, water quality, cable and drop pipe problems. Repeated shocking of a well can make an IRB problem worse because they produce slime and encrustations that chlorine can not penetrate. Then you get into well cleaning and/or rehabilitation if it can be done.
Pellet droppers should only be used when absolutely needed. They can cause pump and cable problems but if the dose is fine tuned those problems don't happen; especially in a 5" or larger diameter well as you have.
About 99% of all softeners can have the resin replaced. Most control valves like Autotrol, Clack, Erie or Fleck can be rebuilt very affordably. Many national brands use those brands of control valves but don't tell you which one but it's easy to find pictures on the internet and compare. Some of those national brands use a proprietary version of the stock valves; like most of WaterCare valves.
You haven't said how much of a problem the IRB is. It may not be the cause of your softener's problem.
Any odor to this water?
How much iron in the water?
How much hardness?
What is the pH?
Are you interested in being a DIYer or do you want to be dependent on a local dealer for service and parts?
Gary Slusser is offline   Reply With Quote
Old 03-17-2009, 04:07 PM   #23
Rewards Points: 150
Okay I have done a little more research;
My hardness is 13 grains right now, pre softener.
I don't know how big of a problem the bacteria really is, there is no funky smell or anything offensive. The ONLY reason I am concerned about it is that my water softener stopped working and the water treatment company suggested that it was clogged with Iron bacteria.
Now, this softener is OLD! Like 20 years +. It seems to cycle normally and there are no real apparent issues with it. It just won't soften.
I purchased a new kenmore unit with auto regeneration etc.. to cut down on salt use. There is only two of us living here at this time. Hypothetically I can return it.
If the iron bacteria is gauranteed to kill a softener every 10 years, whatever. I can live with that. This unit failed within a year of me moving in.
I find it hard to believe that the previous owner shocked the well or did anything to maintain it judging by the rest of the house.
So are you saying I can essentially force feed it bleach in an attempt to clean out the brine tank? That would be amazing. Ill do it tonight. How would I introduce the bleach into the softener? Putting it into the brine tank?
I am definitely a DIY'er and do not trust water treatment companies to be square with me.. I am very hands on, and very stubborn when it comes to paying people for advice and work that I don't trust.
Thoughts?
Thanks!
Evan
Old 03-17-2009, 05:46 PM   #24
Rewards Points: 150
Gary, I understand your concern as far as the softener goes, the place that my softener came from is hellenbrand.
How much does resin cost and where do I get it? How much would I need? The resin tank is about 8-10" diameter and 4' tall or so. I just put new timer in my old softener so essentially the only other thing that can go wrong is the valves.
I do have the iron sludge crap in my toilet tanks etc... so I am pretty confident that there is iron bacteria. My only real concern is keeping it from ruining my water softener.
Evan
EDIT; Just added bleach and started the regeneration process.
Old 03-17-2009, 06:14 PM   #25
But if the toilet tank hadn't been cleaned in years, you may not have enough IRB in the water to do anything to the softener. To treat IRB you must kill it with a disinfectant like chlorine of ozone, hydrogen peroxide usually doesn't work well on reducing type of bacteria.
You can buy resin from any online or most local dears. An 8" diameter tank, the model number on the label gives you the size, an 844 is a 3/4 cuft and 948 is a 1 cuft etc..
Old 03-17-2009, 08:13 PM   #26
Rewards Points: 150
How long is normal for a cycle time for a water softener? I just replaced the timer on it because it was noisy and dying. I just turned the softener to regenerate and it didn't even seem to be moving....... it stayed on backflush for over an hour??
Thanks!
EDIT;
Aw man! I just figured out that I left out a spring washer that engages the assembly to ensure it moves through the cycles at the correct speed. I took it apart and was confused as to how it worked.. then I saw the SS spring washer sitting right in front of my face.
DUH.
Not sure if the softener is working correctly still. I think the diagnosis of iron bacteria is accurate. There is a fairly gross film on top of my brine tank. I also replaced the sediment filter which was downright nasty. Red as could be. It was doing its job. Maybe the skin is somewhat normal ontop of the brine water but I don't remember it being that bad when we moved in. I took the brine tank out and power washed it before we moved in. In the last year it has gotten scummier (is that a word?) than it was when we moved in.
Evan
Old 03-18-2009, 09:14 AM   #27
Rewards Points: 150
Gary, I have a fleck 5600 valve on this unit BTW. I figured that out after looking at your site. I also found a local source for resin, I have today off so I am going to go get some.
Evan
Old 03-19-2009, 07:39 PM   #28
Rewards Points: 150
Alright, took the bull by the horns and replaced the resin and rock today. Man, thats pretty easy stuff...
Thank you for your encouragement.. now hopefully it works!
Gary, I tried emailing you through your site without any luck. Please send me an email regarding a rebuild kit for the 5600.
Evan
BTW; The resin and rock was so inexpensive @ 100 bucks that I decided to leave the well and see how long it takes to clog this media up...
Old 03-19-2009, 10:40 PM   #29
sanitizing the well and water system
Here is one of many websites: http://www.fcs.uga.edu/pubs/PDF/HACE-858-4.pdf or http://www.thehome-inspection.com/waterwells.htm ( google to find many more) that tell you how to sanitize your well and all your plumbing. If your Ph is very high (above 8 or so) you may not get the effect you want for the given amount of chorline suggested. Also be sure to include all your indoor piping (including the water heater) when you introuce chorine into the home. Note that you should "backflush" your softener after you let the water stand for 24 hours or so, before you clear the water lines. This should help eliminate your current problem with the softener hopefully.
The one thing to pick out of the info is that if you have a high concentration of iron in your well , there is a high probability that you will have to continually deal with iron bacteria occuring.
HAVE FOUND IN MY 150 FT. WELL THAT THE CHORINE SMELL IS GONE IN A FEW HOURS AFTER TURNING ON AN OUTSIDE FAUCET. If you R concerned about the pump when you run the water to clear the chorine, then run the water faucet in increments.
I have to deal with iron bacteria also, but after doing a shock cholorination once a year, I only drop a few tablets down the well once a month and it seems to keep the problem from coming back (I have an acitivated (centaur) carbon whole house filter to keep the cholrine out of my water lines). An alternative to placing the cholrine oin the well is to have a holding tank, as previously suggested and install a chorinator chmical feeder. There R other ways as well(from one vendor's source):
Injection of small amounts of chlorine directly into water line with no retention tank, and not using well for retention. Most commonly used for sulfur smell (rotten egg smell) removal. Most inexpensive method of chlorination. OR:
(2) Chlorination Inside the well itself (using the well as a retention tank) OR:
(3) Chlorination Outside the well with an add on retention tank OR:
(4) Chlorine/Aeration Open-Air System
Good luck
jabass is offline   Reply With Quote
Old 03-19-2009, 11:37 PM   #30
Rewards Points: 150
Thanks for the help, Ill check out your suggestions and information. I appreciate it.
My water looks a hint of orange if viewed in a gallon container.
Evan
Water Softener, need some good advice. wla6518 Plumbing 11 07-07-2011 10:09 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
