Old 07-30-2008, 08:14 PM   #1
Darn. A leak in my main supply from street, Galvanized. In foundation under slab?
Ok guys I was redoing all of my supply lines with PEX. I removed all of the old galvanized. The old galvanized wasn't that bad. I connected all of my PEX and it came out great. However, the main supply comes in through the foundation and is completely underneath a large concrete slab. I noticed that the galvanized supply has a small leak in it. It looks like it rusted from the outside. How I am not sure. The inside doesn't look that bad. Would it be possible to put a pipe wrench on it and see if I can unscrew that piece of galvanized and install a new piece. I know there is a 90 on the end of it but I don't know how far back it goes. My meter is about 70 feet from the supply so I don't want to run a complete new line if I can help it. Any info would be appreciated.
twilightcall is offline   Reply With Quote
Old 07-30-2008, 10:27 PM   #2
Send a message via AIM to Marlin
The 90 is outside the foundation right? If it is forget it you'll just end up breaking the pipe. Even if you do get it out you will never get another line in as the hole will fill with dirt.
Marlin is offline   Reply With Quote
Old 07-31-2008, 01:22 AM   #3
Doing it myself
Alan's Avatar
x2 on this.
You're better off fixing it (change to pvc), however, if there's any way at all to get around the concrete.
Journeyman Plumber
Alan is online now   Reply With Quote
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Sewer leak below slab. Debris in sand. martin52 Plumbing 2 10-20-2006 09:43 AM
