Danze Showerhead Runs Even When Turned Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2012, 05:28 PM   #1
Danze showerhead runs even when turned off
I have three of valves (Danze D135300BT Single Handle 3/4 Volume Control Valve) in my shower and recently one of them began running even when the valve is completely closed. It seems that water is leaking around the cartridge - not a good seal. Danze has send me three replacement cartridges, but all of them begin to leak within 10 minutes of installing them in the valve. Weird thing is that if I move one of the original cartridges from another valve, the leak stops. Danze tells me there is only one cartridge and there's no chance they are mailing me the wrong part. Any help would be appreciated - I've run out of ideas!
mgenkin is offline   Reply With Quote
Shower gooseneck turned jcnova Plumbing 2 07-31-2010 08:55 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 10:33 PM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 04:44 PM
moving wiring runs in attic DoubleD07 Electrical 1 07-23-2007 07:44 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 11:49 AM
