D Box Is Full Of Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2010, 04:21 PM   #1
D Box is full of water
So, my wife came in two days ago and said it smelled like septic outside. Upon investigating, I found that our distribution box on our septic was full of water. Keep in mind, she had done several loads of laundry in the morning, but this has never been a problem in the past. Could it be that our septic just need to be pumped, or a bigger problem? Any ideas?
kcuningham is offline   Reply With Quote
Old 04-11-2010, 05:21 PM   #2
Civil Engineer
Rewards Points: 4,856
Don't know your location. In MA a distribution box full of effluent (that aint water in there) is an immediate failure of the system. Pumping the system typically does nothing, since a full distribution box normally means the septic field is clogged and non-functional. Don't know the rules in your area, but in MA you would need an inspection by a licensed septic inspector, followed by design of a new system by a licensed professional engineer, unless you can fix the system.
In some rural areas, the rules are much less stringent. However, a full D-box is generally very bad news.
Old 04-11-2010, 06:34 PM   #3
are you looking in the septic tank, normaly the distribution box is harder to find. they(dist box) also can get out of level and only be using one line which can cause a backup
The older I get the better I was
Old 04-11-2010, 09:33 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
pull the lid off your tank and see whats in there if you havent already
plummen is offline   Reply With Quote
Old 04-11-2010, 09:56 PM   #5
Rewards Points: 1,538
Can you see in the distribution box that each of the leach field lines (fingers) is receiving a fair share of liquid?
What is in the septic tank itself will not have any immediate effect on the liquid level in the d-box but excessive scum (contains grease) or excessive sludge in the tank could mean that some of those materials found their way out past the d-box into the leach field, degrading the performance of the latter.
Old 04-11-2010, 10:01 PM   #6
plummen's Avatar
im thinking he might be confusing the tank for the dist box,tank should definately be easier to find
Old 04-12-2010, 12:13 PM   #7
Actually, I know it's the D box. We're having the septic pumped today and they're going to run a camera down the D box to check things out.
Old 04-12-2010, 12:17 PM   #8
Well, we found out this morning that we havent had the tank pumped in 5 years. Hoping this is part of the problem. It looked like it was draining ok initially, then it filled up again. Keep in mind that I had cleaned it out completely, then I ran water down the cleanout until the water ran into the D box. It filled back up after that.
Old 04-12-2010, 09:20 PM   #9
plummen's Avatar
thats not a good sign!
Old 04-12-2010, 09:41 PM   #10
Rewards Points: 352
This is probably going to hurt
plumberinlaw is offline   Reply With Quote
Old 04-12-2010, 09:45 PM   #11
plummen's Avatar
im guessing you have piped laterals instead of domes?
Old 04-12-2010, 11:13 PM   #12
Civil Engineer
I have read a number of analyses of the required frequency of pumping septic tanks. In general, if you do not add excessive grease to the system, and keep your solids load low by not using a garbage grinder, most systems can go more than ten years without the need to pump. In fact, many systems never need to be pumped. It is easy to tell if your septic tank needs to be pumped, you open the access manhole and probe down to the bottom with a wooden stick and determine the depth of solids. If the tank is less than 10 percent full, no need to pump.
So unless you are putting something really bad down your system, pumping the tank is not likely to improve your situation. The most probable cause of backup of the D-box is a clogged septic field, which in most states will have to be replaced. There are all sorts of claimed remedies for clogged systems, including peroxide and other harsh chemicals, these are all illegal in MA, don't know about your state. Where I live, a clogged field must be replaced.
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 01:56 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 07:38 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
