Cycle Stop Vlave - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2014, 07:39 PM   #1
Rewards Points: 150
cycle stop vlave
cycle stop valve in a residential well system yes or no?
hpyjack2013 is offline   Reply With Quote
Old 02-05-2014, 09:08 PM   #2
Rewards Points: 3,130
Maybe.
Old 02-05-2014, 09:17 PM   #3
Rewards Points: 150
that answers that question
Old 02-05-2014, 09:33 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yes, or No, depending on your reasoning for wanting to install one.
Journeyman Plumber
Old 02-05-2014, 09:41 PM   #5
Rewards Points: 150
I've read it supposedly makes the pump last longer. It's just the wife and I, but it seems the pump cycles on and off a lot.
Old 02-05-2014, 09:58 PM   #6
Doing it myself
Alan's Avatar
I just did a little reading on it since i've never installed one.
It seems like it will do what you're intending, but first I would make sure that you don't possibly have a leak somewhere that is causing the pump to cycle on and off a lot.
From what I read, it basically allows you to squeeze all pressurized water out of the pressure tank before the pump will kick back on. This just means a longer run time for the pump rather than more frequent short run times.
As a general rule, if something isn't a necessity for the system to operate, you're adding another device to fail that will cause troubleshooting issues down the road somewhere. Before putting something like that in, i'd definitely make sure the system is running as intended and all the components are in good working order.
Hopefully somebody who has experience with these things will click on your thread, because unfortunately that's all I have to offer on the subject.
Journeyman Plumber
Old 02-05-2014, 10:07 PM   #7
Rewards Points: 150
the pump and tank were replaced last year, and while I was researching them I came across them. I also increased the tank size. Pump only cycles when faucet is running, Thing that caught my attention was even when faucet was just trickling. I have to check pressure in tank, but it should be alright thanks
Old 02-05-2014, 11:35 PM   #8
Rewards Points: 444
The tank that was installed will have a draw down number in gallons. If it was set up correctly the pump will operate between the cut out (stop) and cut in (start) parameters close to those gallons specified in the specifications.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
hpyjack2013 (02-06-2014)
Old 02-06-2014, 08:44 PM   #9
Rewards Points: 1,700
I would look real hard at the well pressure tank. Make sure no water shows up on top snifter valve. Also make sure tank has proper air pressure.
The Following User Says Thank You to Ghostmaker For This Useful Post:
dishwasher stuck on drain cycle DanDaMan Appliances 2 01-03-2014 07:54 PM
Heating Cycle Rate, mid efficiency. pete0403 HVAC 4 03-25-2013 08:52 PM
Shower drain wont stop (pictures) homeowner432423 Plumbing 12 01-15-2012 10:49 PM
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 07:07 PM
Air jets in walk in tub sporadically stop working Bath Plumbing 0 07-20-2011 12:35 PM
